Introdução
If you are unable to play a CD/DVD on your laptop, there is most likely damage to the optical drive. Use this guide to help replace the drive in order to restore the laptop back to normal working conditions.
O que você precisa
Slide the battery removal switch towards the center of the laptop until the battery pops out.
Use the screwdriver to remove the 4mm Phillips #0 screw holding the optical drive in.
2 comentários
What do you do when the DVD drive will NOT slide out? That’s my problem. There’s no disk inside; the unit is simply stuck shut. Now what do you do?
For me, the DVD drive connection had, what I think was soda, inside of the port and it acted like a sort of glue so brute force may be the option.
After a deep cleaning of the connections, it worked like new.
