Introdução
If you need to replace hard drive in your HP Pavilion g7-1150us use this guide. The hard drive holds all the information stored on your laptop so if you have error saying your hard drive has been corrupted try replacing it. You will need an iFixit opening tool and Phillips #0 screwdriver. No steps are difficult but make sure to remove the battery first so you don’t hurt your laptop or yourself.
O que você precisa
Slide the battery removal switch towards the center of the laptop until the battery pops out.
Grab the hard drive gently on either side. The left side is where the hard drive is connected to the laptop.
