Ir para o conteúdo principal
HP Pavilion g7-1150us Hard Drive Replacement
O que você precisa
  1. HP Pavilion g7-1150us Hard Drive Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion g7-1150us Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Slide the battery removal switch towards the center of the laptop until the battery pops out.
  2. HP Pavilion g7-1150us Hard Drive Replacement: passo 2, imagem 1 %32
    • Remove the battery from the computer.
  3. HP Pavilion g7-1150us Hard Drive Replacement, Surface Panel: passo 3, imagem 1 %32
    • Unscrew the two 4mm Phillips #0 screws found in the surface panel.
  4. HP Pavilion g7-1150us Hard Drive Replacement: passo 4, imagem 1 %32 HP Pavilion g7-1150us Hard Drive Replacement: passo 4, imagem 2 %32
    • Using the spudger, pry the surface panel off starting from the side where the battery was located.
    • Pry the remainder of the panel off by sliding the spudger underneath the panel and gently lifting.
    • Aim for the corners of the panel while using the spudger to methodically remove it without damaging it.
  5. HP Pavilion g7-1150us Hard Drive Replacement: passo 5, imagem 1 %32
    • Lift the pried surface panel off of the computer.
  6. HP Pavilion g7-1150us Hard Drive Replacement, Hard Drive: passo 6, imagem 1 %32
    • Grab the hard drive gently on either side. The left side is where the hard drive is connected to the laptop.
    • The hard drive was missing from our device.
  7. HP Pavilion g7-1150us Hard Drive Replacement: passo 7, imagem 1 %32
    • Gently pull the hard drive to the right away from the connector. When fully disconnected you have safely removed the hard drive!
Conclusão
Gabriel Lurz
Membro desde: 03/20/19
127 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team S6-G3, Peak Spring 2019 Membro de UMass Dartmouth, Team S6-G3, Peak Spring 2019
UMASSD-PEAK-S19S6G3
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 17
Duração total: 807
