Ir para o conteúdo principal
HP Pavilion g6-2228tx RAM Replacement
O que você precisa
  1. HP Pavilion g6-2228tx RAM Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion g6-2228tx RAM Replacement, Battery: passo 1, imagem 2 %32
    • Push the battery latch to the left to release the battery.
    • Remove the battery from the device.
  2. HP Pavilion g6-2228tx RAM Replacement, Hard Drive: passo 2, imagem 1 %32 HP Pavilion g6-2228tx RAM Replacement, Hard Drive: passo 2, imagem 2 %32
    • Use a Phillips #0 screw driver to loosen the screw. The screw will not detach from the cover.
  3. HP Pavilion g6-2228tx RAM Replacement: passo 3, imagem 1 %32 HP Pavilion g6-2228tx RAM Replacement: passo 3, imagem 2 %32 HP Pavilion g6-2228tx RAM Replacement: passo 3, imagem 3 %32
    • Place your hand on the cover and slide the cover down.
    • Use your hand to lift the cover from the bottom right and slide the cover to the right to remove the cover.
  4. HP Pavilion g6-2228tx RAM Replacement: passo 4, imagem 1 %32 HP Pavilion g6-2228tx RAM Replacement: passo 4, imagem 2 %32
    • Place one finger on the right side of the hard drive.
    • Push the hard drive to the left and lift the hard drive up to remove it from the device.
  5. HP Pavilion g6-2228tx RAM Replacement: passo 5, imagem 1 %32 HP Pavilion g6-2228tx RAM Replacement: passo 5, imagem 2 %32
    • Disconnect the connecting part by pulling the part to the right.
    • Remove the hard drive from the device.
  6. HP Pavilion g6-2228tx RAM Replacement, RAM: passo 6, imagem 1 %32 HP Pavilion g6-2228tx RAM Replacement, RAM: passo 6, imagem 2 %32
    • The silver hinges holds the RAM in place.
  7. HP Pavilion g6-2228tx RAM Replacement: passo 7, imagem 1 %32 HP Pavilion g6-2228tx RAM Replacement: passo 7, imagem 2 %32
    • Use two fingers to push both silver hinges outward to release the RAM.
    • The released RAM will pop up.
  8. HP Pavilion g6-2228tx RAM Replacement: passo 8, imagem 1 %32
    • Pull the RAM stick to the left and remove it from the device.
Conclusão
Hai Lin
Membro desde: 10/19/18
446 Reputação
Autoria de 4 guias
Equipe
UC Davis, Team S4-G6, Lore Fall 2018 Membro de UC Davis, Team S4-G6, Lore Fall 2018
UCD-LORE-F18S4G6
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 709
