Ir para o conteúdo principal
HP Pavilion g6-1b79dx Wireless Card Replacement
O que você precisa
  1. HP Pavilion g6-1b79dx Wireless Card Replacement, Battery: passo 1, imagem 1 %32
    • Flip the computer so the bottom is facing up with the battery away from you.
    • Turn off the computer and disconnect the charger.
  2. HP Pavilion g6-1b79dx Wireless Card Replacement: passo 2, imagem 1 %32 HP Pavilion g6-1b79dx Wireless Card Replacement: passo 2, imagem 2 %32
    • Slide the battery switch to the left until the battery unlatches from the base of the laptop.
  3. HP Pavilion g6-1b79dx Wireless Card Replacement: passo 3, imagem 1 %32 HP Pavilion g6-1b79dx Wireless Card Replacement: passo 3, imagem 2 %32
    • Lift the battery from its compartment away from the laptop.
  4. HP Pavilion g6-1b79dx Wireless Card Replacement, Bottom Panel: passo 4, imagem 1 %32
    • Loosen the two 5.7 mm screws on the bottom panel using a PH00 screwdriver.
    • The screws do not come out of the panel due to small washers. Do not try to remove the screws completely.
  5. HP Pavilion g6-1b79dx Wireless Card Replacement: passo 5, imagem 1 %32
    • Use the metal spudger all around the panel to pop it up from the base.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Using your finger is acceptable but not entirely recommended. Be gentle if you choose to use your hands.
  6. HP Pavilion g6-1b79dx Wireless Card Replacement: passo 6, imagem 1 %32 HP Pavilion g6-1b79dx Wireless Card Replacement: passo 6, imagem 2 %32 HP Pavilion g6-1b79dx Wireless Card Replacement: passo 6, imagem 3 %32
    • With your hands, lift the panel completely off the base of the laptop.
  7. HP Pavilion g6-1b79dx Wireless Card Replacement, Wireless Card: passo 7, imagem 1 %32 HP Pavilion g6-1b79dx Wireless Card Replacement, Wireless Card: passo 7, imagem 2 %32 HP Pavilion g6-1b79dx Wireless Card Replacement, Wireless Card: passo 7, imagem 3 %32
    • Unlatch the two antenna cable connectors from the wireless card.
  8. HP Pavilion g6-1b79dx Wireless Card Replacement: passo 8, imagem 1 %32
    • Remove the two 2.5 mm screws in the wireless card with a PH00 screwdriver.
    • You may have to gently bend the cables away from the wireless card to remove the screws
  9. HP Pavilion g6-1b79dx Wireless Card Replacement: passo 9, imagem 1 %32 HP Pavilion g6-1b79dx Wireless Card Replacement: passo 9, imagem 2 %32 HP Pavilion g6-1b79dx Wireless Card Replacement: passo 9, imagem 3 %32
    • Gently disconnect the wireless card from the laptop.
Conclusão
Rachel Gallegos
Membro desde: 09/22/15
873 Reputação
Autoria de 5 guias
Equipe
Baylor, Team 10-12, Williams Fall 2015 Membro de Baylor, Team 10-12, Williams Fall 2015
BU-WILLIAMS-F15S10G12
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 14
Duração total: 1,369
