Introdução
To remove the laptop's speakers, many components within the laptop need to be removed. This is a guide to do so.
O que você precisa
Loosen the two 5.7 mm screws on the bottom panel using a PH00 screwdriver.
Use the PH 00 screwdriver to unscrew the 2.5 mm screw to the right of the hard drive.
Using a PH 00 screwdriver, remove the screw located next to the wireless card.
With the laptop bottom facing up, locate the rubber plug on the right side of the computer.
Use a metal splunger to remove the plug.
10 outras pessoas executaram este guia.
2 comentários
I Love the practical very much
HP Pavilion g6 price
