Introdução
Components below the laptop need to be removed before you can detach the keyboard. This is a guide to remove your laptop's keyboard.
O que você precisa
Loosen the two 5.7 mm screws on the bottom panel using a PH00 screwdriver.
Using a PH 00 screwdriver, remove the screw located next to the wireless card.
9 outras pessoas executaram este guia.
