Ir para o conteúdo principal
HP Pavilion g6-1b79dx Keyboard Replacement
O que você precisa
  1. HP Pavilion g6-1b79dx Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Flip the computer so the bottom is facing up with the battery away from you.
    • Turn off the computer and disconnect the charger.
  2. HP Pavilion g6-1b79dx Keyboard Replacement: passo 2, imagem 1 %32 HP Pavilion g6-1b79dx Keyboard Replacement: passo 2, imagem 2 %32
    • Slide the battery switch to the left until the battery unlatches from the base of the laptop.
  3. HP Pavilion g6-1b79dx Keyboard Replacement: passo 3, imagem 1 %32 HP Pavilion g6-1b79dx Keyboard Replacement: passo 3, imagem 2 %32
    • Lift the battery from its compartment away from the laptop.
  4. HP Pavilion g6-1b79dx Keyboard Replacement, Bottom Panel: passo 4, imagem 1 %32
    • Loosen the two 5.7 mm screws on the bottom panel using a PH00 screwdriver.
    • The screws do not come out of the panel due to small washers. Do not try to remove the screws completely.
  5. HP Pavilion g6-1b79dx Keyboard Replacement: passo 5, imagem 1 %32
    • Use the metal spudger all around the panel to pop it up from the base.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Using your finger is acceptable but not entirely recommended. Be gentle if you choose to use your hands.
  6. HP Pavilion g6-1b79dx Keyboard Replacement: passo 6, imagem 1 %32 HP Pavilion g6-1b79dx Keyboard Replacement: passo 6, imagem 2 %32 HP Pavilion g6-1b79dx Keyboard Replacement: passo 6, imagem 3 %32
    • With your hands, lift the panel completely off the base of the laptop.
  7. HP Pavilion g6-1b79dx Keyboard Replacement, Keyboard: passo 7, imagem 1 %32
    • Using a PH 00 screwdriver, remove the screw located next to the wireless card.
    • You can remove the wireless card for this process but it is not necessary.
    • This screw has a small keyboard icon next to it.
  8. HP Pavilion g6-1b79dx Keyboard Replacement: passo 8, imagem 1 %32
    • Flip the laptop over and open it.
    • The components beneath your computer may be loose and fall out when you flip the laptop. Be careful when turning it over.
  9. HP Pavilion g6-1b79dx Keyboard Replacement: passo 9, imagem 1 %32 HP Pavilion g6-1b79dx Keyboard Replacement: passo 9, imagem 2 %32 HP Pavilion g6-1b79dx Keyboard Replacement: passo 9, imagem 3 %32
    • Insert a plastic spudger or similar pry tool, beneath the keyboard, near the "insert" key, and pop the keyboard up from the laptop.
    • Starting at the opening you just created, run your fingers around the outside of the keyboard separating it from the rest of the computer.
    • Only lift the keyboard up a few inches because it is attached to the laptop by a ribbon cable.
  10. HP Pavilion g6-1b79dx Keyboard Replacement: passo 10, imagem 1 %32 HP Pavilion g6-1b79dx Keyboard Replacement: passo 10, imagem 2 %32 HP Pavilion g6-1b79dx Keyboard Replacement: passo 10, imagem 3 %32
    • Slightly angle the keyboard back so the ribbon connector underneath it is visible.
    • Remove the ribbon cable by using your fingers to pull up and away from the connector.
  11. HP Pavilion g6-1b79dx Keyboard Replacement: passo 11, imagem 1 %32
    • With the ribbon cable detached, you can now completely remove the keyboard.
Conclusão
9 outras pessoas executaram este guia.
patrickhall
Membro desde: 09/23/15
730 Reputação
Autoria de 3 guias
Equipe
Baylor, Team 10-12, Williams Fall 2015 Membro de Baylor, Team 10-12, Williams Fall 2015
BU-WILLIAMS-F15S10G12
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 46
Duração total: 6,866
