Ir para o conteúdo principal
HP Pavilion g4-1117dx Screen Replacement
O que você precisa
  1. HP Pavilion g4-1117dx Screen Replacement, Battery: passo 1, imagem 1 %32
    • Slide pill shaped tab to the other side of the channel.
    • Remove battery while keeping the tab to the side.
  2. HP Pavilion g4-1117dx Screen Replacement, Screen: passo 3, imagem 1 %32 HP Pavilion g4-1117dx Screen Replacement, Screen: passo 3, imagem 2 %32 HP Pavilion g4-1117dx Screen Replacement, Screen: passo 3, imagem 3 %32
    • Remove two triangular shaped screw covers in the bottom corners of the monitor near the hinges.
    • Unscrew the two 4.0 mm JIS #0 screws holding the hinge covers.
  3. HP Pavilion g4-1117dx Screen Replacement: passo 4, imagem 1 %32
    • Pry off the monitor border cover.
  4. HP Pavilion g4-1117dx Screen Replacement: passo 5, imagem 1 %32 HP Pavilion g4-1117dx Screen Replacement: passo 5, imagem 2 %32
    • Remove four 4.0mm JIS #0 screws located at each corner of the monitor.
  5. HP Pavilion g4-1117dx Screen Replacement: passo 6, imagem 1 %32 HP Pavilion g4-1117dx Screen Replacement: passo 6, imagem 2 %32 HP Pavilion g4-1117dx Screen Replacement: passo 6, imagem 3 %32
    • Remove the two silver hinge covers.
  6. HP Pavilion g4-1117dx Screen Replacement: passo 7, imagem 1 %32 HP Pavilion g4-1117dx Screen Replacement: passo 7, imagem 2 %32
    • Unplug at golden connector.
  7. HP Pavilion g4-1117dx Screen Replacement: passo 8, imagem 1 %32 HP Pavilion g4-1117dx Screen Replacement: passo 8, imagem 2 %32 HP Pavilion g4-1117dx Screen Replacement: passo 8, imagem 3 %32
    • Remove four 3.0mm JIS #0 screws, two on each side of the screen.
  8. HP Pavilion g4-1117dx Screen Replacement: passo 9, imagem 1 %32
    • Carefully remove the screen.
Conclusão
Uma outra pessoa concluiu este guia.
Robert Hamilton
Membro desde: 03/01/18
1.165 Reputação
Autoria de 10 guias
Equipe
UMass Dartmouth, Team S2-G7, Simcock Spring 2018 Membro de UMass Dartmouth, Team S2-G7, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G7
Membros da 4
Autoria de 10 guias
Um comentário
nice very informative
S i n o for pc - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 777
