Introdução
Although it does not have many prerequisites, the screen is without a doubt the most difficult part of the laptop to remove. There are several hidden screws and wire that need to be carefully removed.
O que você precisa
Remove two triangular shaped screw covers in the bottom corners of the monitor near the hinges.
Unscrew the two 4.0 mm JIS #0 screws holding the hinge covers.
Uma outra pessoa concluiu este guia.
