Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
The large back panel contains a lot of screws that help keep it in tact. It covers and protects the majority of your device's insides. It can be somewhat tricky to remove.
Peças
Nenhum componente especificado.
  1. Slide pill shaped tab to the other side of the channel.
    • Slide pill shaped tab to the other side of the channel.
    • Remove battery while keeping the tab to the side.
  2. Unscrew the two screws JIS #0 located on opposites sides of the panel.
    • Unscrew the two screws JIS #0 located on opposites sides of the panel.
    • Screws are attached to the panel and will not fully come out.
  3. Kits para o Nintendo Switch
    Um reparo rápido para reiniciar o jogo
    Confira kits para o Nintendo Switch
  4. Carefully pry off the L-shaped panel.
    • Carefully pry off the L-shaped panel.
  5. Unscrew all nine 6.0mm JIS #0 screws located on the border of the back panel.
    • Unscrew all nine 6.0mm JIS #0 screws located on the border of the back panel.
  6. Remove 3 screws located where the battery previously was.
    • Remove 3 screws located where the battery previously was.
  7. Remove 6 screws located under the spot where the smaller L-shaped panel was located. Remove 6 screws located under the spot where the smaller L-shaped panel was located.
    • Remove 6 screws located under the spot where the smaller L-shaped panel was located.
  8. Slowly pry off the keyboard from the back panel.
    • Slowly pry off the keyboard from the back panel.
    • Between the back panel and the keyboard there are two ribbon wires.
    • Remove slowly to not break the back panel. If it does not come off easily, check to see if all screws are removed.
  9. Unplug wires connecting back panel to keyboard.
    • Unplug wires connecting back panel to keyboard.
Conclusão
Robert Hamilton
Membro desde: 01/03/2018
1.051 Reputação
10 Guias de autoria
Equipe
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 153
