Ir para o conteúdo principal
HP Pavilion g4-1117dx Fan Replacement
O que você precisa
  1. HP Pavilion g4-1117dx Fan Replacement, Battery: passo 1, imagem 1 %32
    • Slide pill shaped tab to the other side of the channel.
    • Remove battery while keeping the tab to the side.
  2. HP Pavilion g4-1117dx Fan Replacement, L-Shaped Back Panel: passo 3, imagem 1 %32
    • Unscrew the two screws JIS #0 located on opposites sides of the panel.
    • Screws are attached to the panel and will not fully come out.
  3. HP Pavilion g4-1117dx Fan Replacement: passo 4, imagem 1 %32
    • Carefully pry off the L-shaped panel.
  4. HP Pavilion g4-1117dx Fan Replacement, Hard Drive: passo 5, imagem 1 %32
    • Pull out and unplug the tab on the right hand side.
  5. HP Pavilion g4-1117dx Fan Replacement, Larger Back Panel: passo 6, imagem 1 %32
    • Unscrew all nine 6.0mm JIS #0 screws located on the border of the back panel.
  6. HP Pavilion g4-1117dx Fan Replacement: passo 7, imagem 1 %32
    • Remove 3 screws located where the battery previously was.
  7. HP Pavilion g4-1117dx Fan Replacement: passo 8, imagem 1 %32 HP Pavilion g4-1117dx Fan Replacement: passo 8, imagem 2 %32
    • Remove 6 screws located under the spot where the smaller L-shaped panel was located.
  8. HP Pavilion g4-1117dx Fan Replacement: passo 9, imagem 1 %32
    • Slowly pry off the keyboard from the back panel.
    • Between the back panel and the keyboard there are two ribbon wires.
    • Remove slowly to not break the back panel. If it does not come off easily, check to see if all screws are removed.
  9. HP Pavilion g4-1117dx Fan Replacement: passo 10, imagem 1 %32
    • Unplug wires connecting back panel to keyboard.
  10. HP Pavilion g4-1117dx Fan Replacement, Motherboard: passo 11, imagem 1 %32 HP Pavilion g4-1117dx Fan Replacement, Motherboard: passo 11, imagem 2 %32
    • In lower left hand corner, pull on black tab to unplug the disc drive.
  11. HP Pavilion g4-1117dx Fan Replacement: passo 12, imagem 1 %32 HP Pavilion g4-1117dx Fan Replacement: passo 12, imagem 2 %32
    • In upper left hand corner, unplug the large black electrical tape covered laptop plug.
  12. HP Pavilion g4-1117dx Fan Replacement, Fan: passo 13, imagem 1 %32 HP Pavilion g4-1117dx Fan Replacement, Fan: passo 13, imagem 2 %32
    • Unscrew the four screws JIS #0 screws on the back side of the motherboard.
    • Screws will loosen but do not come completely out.
    • The screws are the only thing keeping the fan attached to the motherboard.
Conclusão
Robert Hamilton
Membro desde: 03/01/18
1.165 Reputação
Autoria de 10 guias
Equipe
UMass Dartmouth, Team S2-G7, Simcock Spring 2018 Membro de UMass Dartmouth, Team S2-G7, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G7
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 14
Duração total: 1,933
