Ir para o conteúdo principal
HP Pavilion dv9000 Wireless Card Replacement
O que você precisa
  1. HP Pavilion dv9000 Wireless Card Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 Wireless Card Replacement, Battery Removal: passo 2, imagem 1 %32 HP Pavilion dv9000 Wireless Card Replacement, Battery Removal: passo 2, imagem 2 %32
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: passo 3, imagem 1 %32 HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: passo 3, imagem 2 %32 HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: passo 3, imagem 3 %32
    • Locate the panel that lies in the front center of the laptops underside.
    • Using a Phillips #1 screwdriver, remove the two 5mm screws on the forward end of the cover.
    • Lift off the cover to expose the Wi-Fi card underneath.
  4. HP Pavilion dv9000 Wireless Card Replacement: passo 4, imagem 1 %32 HP Pavilion dv9000 Wireless Card Replacement: passo 4, imagem 2 %32 HP Pavilion dv9000 Wireless Card Replacement: passo 4, imagem 3 %32
    • Locate the Wi-Fi card inside of the computer.
    • With a Phillips #1 screwdriver, remove the two 11mm screws on either side of the wires attached to the top of the Wi-Fi card.
    • Lift the card from its resting location. Be careful, the card and attached wires are fragile.
  5. HP Pavilion dv9000 Wireless Card Replacement: passo 5, imagem 1 %32 HP Pavilion dv9000 Wireless Card Replacement: passo 5, imagem 2 %32
    • Carefully pop the wires off of the Wi-Fi card. They should easily come off with a light tug.
    • As you take each wire off, keep track of the numbered labels. These numbers correspond with contact points on the card.
Conclusão
Erik Hoffnagle
Membro desde: 04/11/13
768 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 10-32, Maness Winter 2014 Membro de Cal Poly, Team 10-32, Maness Winter 2014
CPSU-MANESS-W14S10G32
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 3,965
