Ir para o conteúdo principal
HP Pavilion dv9000 RAM Replacement
O que você precisa
  1. HP Pavilion dv9000 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 RAM Replacement, Battery Removal: passo 2, imagem 1 %32 HP Pavilion dv9000 RAM Replacement, Battery Removal: passo 2, imagem 2 %32
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 RAM Replacement, RAM: passo 3, imagem 1 %32 HP Pavilion dv9000 RAM Replacement, RAM: passo 3, imagem 2 %32 HP Pavilion dv9000 RAM Replacement, RAM: passo 3, imagem 3 %32
    • Locate the middle plastic cover on the bottom of the laptop.
    • Unscrew the two 5mm screws using a Phillips #1 screwdriver. The screws should remain in the plastic cover.
    • Lift and remove the plastic cover.
  4. HP Pavilion dv9000 RAM Replacement: passo 4, imagem 1 %32 HP Pavilion dv9000 RAM Replacement: passo 4, imagem 2 %32 HP Pavilion dv9000 RAM Replacement: passo 4, imagem 3 %32
    • Locate the RAM card and the metal tabs on either side of it.
    • Press both tabs away from the RAM card to release it. The card should flip up towards you.
    • Carefully lift the RAM card out.
Conclusão
Uma outra pessoa concluiu este guia.
Erik Hoffnagle
Membro desde: 04/11/13
768 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 10-32, Maness Winter 2014 Membro de Cal Poly, Team 10-32, Maness Winter 2014
CPSU-MANESS-W14S10G32
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 3,557
