Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Turn the computer off and disconnect if from all power sources.
Hold the release switch all of the way to the left and your other hand to pull the battery out.
Remove service hatch by sliding away from the computer and lifting up.
Remove the single Phillips #00 screw.
Flip the laptop over.
Wedge a spudger in between the keyboard and the upper bezel (nearest the screen).
Pry upward to release the keyboard clips.
Use the flat end of a spudger to flip up the black tab on the ZIF connectors.
Pull the ribbon cables out of the ZIF connectors.
Remove the keyboard.
