Ir para o conteúdo principal
HP Pavilion dv7t-7000 Keyboard Replacement
O que você precisa
  1. HP Pavilion dv7t-7000 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Turn the computer off and disconnect if from all power sources.
  2. HP Pavilion dv7t-7000 Keyboard Replacement: passo 2, imagem 1 %32
    • Slide the battery release switch to the left.
  3. HP Pavilion dv7t-7000 Keyboard Replacement: passo 3, imagem 1 %32
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. HP Pavilion dv7t-7000 Keyboard Replacement, Back Panel: passo 4, imagem 1 %32
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. HP Pavilion dv7t-7000 Keyboard Replacement: passo 5, imagem 1 %32 HP Pavilion dv7t-7000 Keyboard Replacement: passo 5, imagem 2 %32
    • Remove service hatch by sliding away from the computer and lifting up.
  6. HP Pavilion dv7t-7000 Keyboard Replacement, Keyboard: passo 6, imagem 1 %32 HP Pavilion dv7t-7000 Keyboard Replacement, Keyboard: passo 6, imagem 2 %32
    • Remove the single Phillips #00 screw.
    • Flip the laptop over.
  7. HP Pavilion dv7t-7000 Keyboard Replacement: passo 7, imagem 1 %32 HP Pavilion dv7t-7000 Keyboard Replacement: passo 7, imagem 2 %32 HP Pavilion dv7t-7000 Keyboard Replacement: passo 7, imagem 3 %32
    • Wedge a spudger in between the keyboard and the upper bezel (nearest the screen).
    • Pry upward to release the keyboard clips.
    • The keyboard is plugged into the motherboard, so be careful not to pull out while lifting keyboard.
  8. HP Pavilion dv7t-7000 Keyboard Replacement: passo 8, imagem 1 %32
    • Use the flat end of a spudger to flip up the black tab on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors.
    • Remove the keyboard.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 520
