Introdução
A guide to remove and replace the heat sink in the HP Pavilion dv7t-7000.
O que você precisa
Push the retraining springs away from the RAM at the same time to unlock the RAM.
Flip the keyboard back over.
Remove the single Phillips #00 screw holding in the CD drive.
Pull out the CD drive.
Once you have removed the motherboard, the heat sink is attached.
Flip over the motherboard/heat sink assembly.
