Ir para o conteúdo principal
HP Pavilion dv7t-7000 Hard Drive Replacement
O que você precisa
  1. HP Pavilion dv7t-7000 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Turn the computer off and disconnect if from all power sources.
  2. HP Pavilion dv7t-7000 Hard Drive Replacement: passo 2, imagem 1 %32
    • Slide the battery release switch to the left.
  3. HP Pavilion dv7t-7000 Hard Drive Replacement: passo 3, imagem 1 %32
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. HP Pavilion dv7t-7000 Hard Drive Replacement, Back Panel: passo 4, imagem 1 %32
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. HP Pavilion dv7t-7000 Hard Drive Replacement: passo 5, imagem 1 %32 HP Pavilion dv7t-7000 Hard Drive Replacement: passo 5, imagem 2 %32
    • Remove service hatch by sliding away from the computer and lifting up.
  6. HP Pavilion dv7t-7000 Hard Drive Replacement, Hard Drive: passo 6, imagem 1 %32
    • Remove the two Phillips #00 screws holding in the hard drive.
  7. HP Pavilion dv7t-7000 Hard Drive Replacement: passo 7, imagem 1 %32 HP Pavilion dv7t-7000 Hard Drive Replacement: passo 7, imagem 2 %32
    • Grab the black tab on the hard drive and pull left and then upwards to remove.
  8. HP Pavilion dv7t-7000 Hard Drive Replacement: passo 8, imagem 1 %32
    • Remove the four Phillips #00 screws holding the hard drive to its case.
  9. HP Pavilion dv7t-7000 Hard Drive Replacement: passo 9, imagem 1 %32 HP Pavilion dv7t-7000 Hard Drive Replacement: passo 9, imagem 2 %32
    • Slide the casing off of the hard drive.
  10. HP Pavilion dv7t-7000 Hard Drive Replacement: passo 10, imagem 1 %32
    • Unplug the hard drive from the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 378
