Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
This guide will show you how to replace the CD drive on a HP Pavilion dv7t-7000 laptop.
Peças
Nenhum componente especificado.
  1. Turn the computer off and disconnect if from all power sources.
    • Turn the computer off and disconnect if from all power sources.
  2. Slide the battery release switch to the left.
    • Slide the battery release switch to the left.
  3. Hold the release switch all of the way to the left and your other hand to pull the battery out.
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Comprar agora
    Comprar agora
  5. Unscrew the single Phillips #00 screw.
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  6. Remove service hatch by sliding away from the computer and lifting up. Remove service hatch by sliding away from the computer and lifting up.
    • Remove service hatch by sliding away from the computer and lifting up.
  7. Remove the single Phillips #00 screw. Remove the single Phillips #00 screw.
    • Remove the single Phillips #00 screw.
  8. Pull CD drive out to remove. Pull CD drive out to remove.
    • Pull CD drive out to remove.
Conclusão
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 58
