Ir para o conteúdo principal
HP Pavilion dv7-6178us WiFi Chip Replacement
O que você precisa
  1. HP Pavilion dv7-6178us WiFi Chip Replacement, WiFi Chip: passo 1, imagem 1 %32 HP Pavilion dv7-6178us WiFi Chip Replacement, WiFi Chip: passo 1, imagem 2 %32
    • Flip over the laptop and push the sliding lock to the right (or whichever side indicates it with a symbol.)
    • After that is done, carefully pull off the back piece. It should look similar to the second photo.
  2. HP Pavilion dv7-6178us WiFi Chip Replacement: passo 2, imagem 1 %32
    • Now that we have the back piece off, we will need to unscrew the two screws holding the WiFi chip in place.
    • Make sure not to lose the screws as they will be needed to replace the WiFi chip.
  3. HP Pavilion dv7-6178us WiFi Chip Replacement: passo 3, imagem 1 %32
    • Remove the WiFi chip from the slot.
Conclusão
Nick Paternostro
Membro desde: 10/15/18
425 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S4-G8, Valliere Fall 2018 Membro de UMass Dartmouth, Team S4-G8, Valliere Fall 2018
UMASSD-VALLIERE-F18S4G8
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 5
Últimos 30 dias: 8
Duração total: 235
