Ir para o conteúdo principal
HP Pavilion dv7-6178us RAM Replacement
  1. HP Pavilion dv7-6178us RAM Replacement, RAM: passo 1, imagem 1 %32 HP Pavilion dv7-6178us RAM Replacement, RAM: passo 1, imagem 2 %32
    • Flip over the laptop and push the sliding lock to the right (or whichever side indicates it with a symbol.)
    • After that is done, carefully pull off the back piece. It should look similar to the second photo.
  2. HP Pavilion dv7-6178us RAM Replacement: passo 2, imagem 1 %32
    • Locate the RAM and push the two tabs on the sides away from the RAM.
  3. HP Pavilion dv7-6178us RAM Replacement: passo 3, imagem 1 %32
    • Once the tabs on the sides are released the RAM card will pop out by itself to this angle, as shown in the picture.
  4. HP Pavilion dv7-6178us RAM Replacement: passo 4, imagem 1 %32
    • Pull the card out of the socket and you have successfully removed one RAM card.
  5. HP Pavilion dv7-6178us RAM Replacement: passo 5, imagem 1 %32 HP Pavilion dv7-6178us RAM Replacement: passo 5, imagem 2 %32
    • Steps 2 through 4 can also be done on the second RAM card, located directly below the initial RAM card.
Conclusão
Branden Simas
Membro desde: 10/20/18
178 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team S4-G8, Valliere Fall 2018 Membro de UMass Dartmouth, Team S4-G8, Valliere Fall 2018
UMASSD-VALLIERE-F18S4G8
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 7
Últimos 30 dias: 21
Duração total: 580
