Ir para o conteúdo principal
HP Pavilion dv7-6178us Hard Drive Replacement
O que você precisa
  1. HP Pavilion dv7-6178us Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32 HP Pavilion dv7-6178us Hard Drive Replacement, Hard Drive: passo 1, imagem 2 %32
    • Flip over the laptop and push the sliding lock to the right (or whichever side indicates it with a symbol.)
    • After that is done, carefully pull off the back piece. It should look similar to the second photo.
  2. HP Pavilion dv7-6178us Hard Drive Replacement: passo 2, imagem 1 %32
    • Now, with the back piece off, you will remove the four screws holding it in place. Use a Phillips head screwdriver.
    • Take note of where you place the screws because you will need them for later.
  3. HP Pavilion dv7-6178us Hard Drive Replacement: passo 3, imagem 1 %32 HP Pavilion dv7-6178us Hard Drive Replacement: passo 3, imagem 2 %32
    • Place the old hard drive off to the side (as seen in photo) and carefully remove the SATA cable from laptop.
    • Be careful to not damage the laptop or cable when doing this step. A gentle pull should do the trick.
Conclusão
Zach Lunghi
Membro desde: 10/19/18
148 Reputação
Autoria de 1 guia
Equipe
Um comentário
This is a really GREAT thing that's being done!
It's high time that consumers fought back and stop letting the TECHNO-OVERLORDS, collectively STRIP us of the right to use the digital tools that we purchase from them.
Walter D Wormack - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 34
Ao todo: 2,046
