Introdução
This guide will instruct you how to remove the touchpad and replace by reversing the steps. There may be some sharp corners underneath you should be cautious of. You may need to replace the touchpad if it has a slow or no response upon placing your finger on the touchpad and moving it.
O que você precisa
Remove service door by prying the plastic opening tool or the spudger under the door.
Lift door and set aside.
Quase terminado!
Conclusão
