Ir para o conteúdo principal
HP Pavilion dv7-4285dx Keyboard Replacement
O que você precisa
  1. HP Pavilion dv7-4285dx Keyboard  Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion dv7-4285dx Keyboard  Replacement, Battery: passo 1, imagem 2 %32
    • Slide the battery release switch to the left. The battery pack will then subsequently release.
  2. HP Pavilion dv7-4285dx Keyboard  Replacement: passo 2, imagem 1 %32
    • Remove the battery pack from the socket.
  3. HP Pavilion dv7-4285dx Keyboard  Replacement, Keyboard: passo 3, imagem 1 %32 HP Pavilion dv7-4285dx Keyboard  Replacement, Keyboard: passo 3, imagem 2 %32 HP Pavilion dv7-4285dx Keyboard  Replacement, Keyboard: passo 3, imagem 3 %32
    • Unscrew the 5 black plate screws using a Ph#0 screwdriver.
    • During the removal process, the back plate will retain the 5 back plate screws.
    • Use a metal spudger to carefully remove back plate.
  4. HP Pavilion dv7-4285dx Keyboard  Replacement: passo 4, imagem 1 %32
    • Unscrew the 7.2mm screws using a Ph#0 screwdriver.
  5. HP Pavilion dv7-4285dx Keyboard  Replacement: passo 5, imagem 1 %32 HP Pavilion dv7-4285dx Keyboard  Replacement: passo 5, imagem 2 %32
    • Push the keyboard release switch using the metal spudger.
  6. HP Pavilion dv7-4285dx Keyboard  Replacement: passo 6, imagem 1 %32 HP Pavilion dv7-4285dx Keyboard  Replacement: passo 6, imagem 2 %32
    • Lift up keyboard from its resting position.
  7. HP Pavilion dv7-4285dx Keyboard  Replacement: passo 7, imagem 1 %32 HP Pavilion dv7-4285dx Keyboard  Replacement: passo 7, imagem 2 %32 HP Pavilion dv7-4285dx Keyboard  Replacement: passo 7, imagem 3 %32
    • Lift up black tab holding ribbon cable.
    • Remove ribbon cable from motherboard.
  8. HP Pavilion dv7-4285dx Keyboard  Replacement: passo 8, imagem 1 %32
    • Remove keyboard.
Conclusão
Austin Sandel
Membro desde: 11/05/18
363 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S1-G2, Baechle Fall 2018 Membro de IUPUI, Team S1-G2, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G2
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 7
Últimos 30 dias: 16
Duração total: 441
