Ir para o conteúdo principal
HP Pavilion dv7-3065dx RAM Replacement
O que você precisa
  1. HP Pavilion dv7-3065dx RAM Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion dv7-3065dx RAM Replacement, Battery: passo 1, imagem 2 %32
    • Turn off the device before removing the battery.
    • Place the laptop upside down on a flat surface so that the bottom is facing up.
    • The battery is the long rectangle above the latch.
  2. HP Pavilion dv7-3065dx RAM Replacement: passo 2, imagem 1 %32
    • Slide the battery latch to the left to release the battery.
  3. HP Pavilion dv7-3065dx RAM Replacement: passo 3, imagem 1 %32 HP Pavilion dv7-3065dx RAM Replacement: passo 3, imagem 2 %32
    • Carefully pull out the battery while holding the latch to the open position with your finger.
  4. HP Pavilion dv7-3065dx RAM Replacement, RAM: passo 4, imagem 1 %32
    • Remove the four circled screws using a #1 philips head screwdriver
    • Note: Be sure to leave the screws in the pannel
    • Pry off cover and place to the side.
  5. HP Pavilion dv7-3065dx RAM Replacement: passo 5, imagem 1 %32
    • The RAM modules will be found on the right side of the access panel
    • CAUTION - The RAM modules are sensitive to electrostatic discharge. It is recommended to wear an anti static bracelet while handling the RAM.
  6. HP Pavilion dv7-3065dx RAM Replacement: passo 6, imagem 1 %32 HP Pavilion dv7-3065dx RAM Replacement: passo 6, imagem 2 %32
    • To remove RAM modules, pry metal tabs out of the modules, and pull ram out (Starting from the top RAM module).
    • Note: The RAM Modules pop out away from the motherboard. In order to replace them, slot the gold plated end into the terminal and push down towards the motherboard.
Conclusão
3 outras pessoas executaram este guia.
Jonathan Winkler
Membro desde: 02/06/17
161 Reputação
Autoria de 1 guia
Equipe
Ohio State, Team 1-5, Wilder Spring 2017 Membro de Ohio State, Team 1-5, Wilder Spring 2017
OSU-WILDER-S17S1G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 21
Duração total: 1,295
