Ir para o conteúdo principal
HP Pavilion dv7-3065dx Keyboard Replacement
O que você precisa
  1. HP Pavilion dv7-3065dx Keyboard Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion dv7-3065dx Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Turn off the device before removing the battery.
    • Place the laptop upside down on a flat surface so that the bottom is facing up.
    • The battery is the long rectangle above the latch.
  2. HP Pavilion dv7-3065dx Keyboard Replacement: passo 2, imagem 1 %32
    • Slide the battery latch to the left to release the battery.
  3. HP Pavilion dv7-3065dx Keyboard Replacement: passo 3, imagem 1 %32 HP Pavilion dv7-3065dx Keyboard Replacement: passo 3, imagem 2 %32
    • Carefully pull out the battery while holding the latch to the open position with your finger.
  4. HP Pavilion dv7-3065dx Keyboard Replacement, Hard Drive: passo 4, imagem 1 %32
    • Loosen the four screws that secure the hard drive panel with a Phillips head screwdriver.
    • Do not completely remove the screws from the panel.
  5. HP Pavilion dv7-3065dx Keyboard Replacement: passo 5, imagem 1 %32
    • Lift the drive cover to expose the hard drive.
    • This device did not have a physical hard drive to work with.
    • Gently tug on the black tabs located on each end of the hard drive in order to loosen the hard drive from the motherboard.
    • Be careful when working with the hard drive cable.
    • Separate the hard drive from the cable by firmly gripping the hard drive and the black plug.
    • Remove the four Phillips screws that secure the hard drive to its carrier.
    • There are two screws on each side.
    • Lift and remove the hard drive from the metal surrounding its perimeter.
  6. HP Pavilion dv7-3065dx Keyboard Replacement, Keyboard: passo 10, imagem 1 %32
    • Locate these seven screws that fasten the keyboard and switch cover to the computer.
    • Remove these screws
  7. HP Pavilion dv7-3065dx Keyboard Replacement: passo 11, imagem 1 %32
    • Flip over the computer to the upright position and locate the switch cover.
    • Carefully pry the switch cover up until it detaches from the computer.
    • The switch cover is held in with plastic clips. They may break if they are removed too forcefully.
  8. HP Pavilion dv7-3065dx Keyboard Replacement: passo 12, imagem 1 %32
    • Raise the switch cover to expose the speaker assembly.
    • Carefully detach the ribbon cables from the speaker assembly.
    • Locate and remove these four screws from the switch cover.
  9. HP Pavilion dv7-3065dx Keyboard Replacement: passo 13, imagem 1 %32 HP Pavilion dv7-3065dx Keyboard Replacement: passo 13, imagem 2 %32
    • Locate and remove the screws that hold the keyboard to the computer.
    • Lift the keyboard up to expose the keyboard connector.
    • The keyboard connector is the small cord located near the screen of the computer.
  10. HP Pavilion dv7-3065dx Keyboard Replacement: passo 14, imagem 1 %32 HP Pavilion dv7-3065dx Keyboard Replacement: passo 14, imagem 2 %32
    • Disconnect the keyboard connector by unhinging the blue plastic clips and gently pulling the cord.
    • The keyboard can now be removed from the computer.
Conclusão
Nicholas Moore
Membro desde: 02/07/17
302 Reputação
Autoria de 2 guias
Equipe
Ohio State, Team 1-5, Wilder Spring 2017 Membro de Ohio State, Team 1-5, Wilder Spring 2017
OSU-WILDER-S17S1G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 1,838
