Ir para o conteúdo principal
HP Pavilion dv7-3065dx Disk Drive Replacement
O que você precisa
  1. HP Pavilion dv7-3065dx Disk Drive Replacement, Disk Drive: passo 1, imagem 1 %32 HP Pavilion dv7-3065dx Disk Drive Replacement, Disk Drive: passo 1, imagem 2 %32
    • Remove the Battery as a safety precaution
    • There is a latch identified in the picture. By sliding this latch to the left, the battery is released from a lock position.
  2. HP Pavilion dv7-3065dx Disk Drive Replacement: passo 2, imagem 1 %32
    • Use a Philips screwdriver to unscrew one screw holding the disk drive to the laptop.
    • In the photo there is a covering missing from another piece of the laptop but this will not impact the disk drive.
  3. HP Pavilion dv7-3065dx Disk Drive Replacement: passo 3, imagem 1 %32
    • Slide (pull) the disk drive out from the laptop and place it off to the side.
    • The disk drive is the silver container as seen in the photo.
Conclusão
Bailey York
Membro desde: 02/07/17
101 Reputação
Autoria de 1 guia
Equipe
Ohio State, Team 1-5, Wilder Spring 2017 Membro de Ohio State, Team 1-5, Wilder Spring 2017
OSU-WILDER-S17S1G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 19
Duração total: 737
