Ir para o conteúdo principal
HP Pavilion dv7-1448dx RAM Replacement
O que você precisa
  1. HP Pavilion dv7-1448dx RAM Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the computer is unplugged and turned off.
    • Place the computer front side down with the battery compartment farthest away.
  2. HP Pavilion dv7-1448dx RAM Replacement: passo 2, imagem 1 %32 HP Pavilion dv7-1448dx RAM Replacement: passo 2, imagem 2 %32
    • Slide the switch under the battery compartment to the left until the compartment opens. This may require some force.
  3. HP Pavilion dv7-1448dx RAM Replacement: passo 3, imagem 1 %32 HP Pavilion dv7-1448dx RAM Replacement: passo 3, imagem 2 %32
    • Lightly pry the battery upward to remove.
    • When reinserting the battery, match the latches along the backside of the battery with the corresponding slots in the computer in order to press it into place.
  4. HP Pavilion dv7-1448dx RAM Replacement, RAM: passo 4, imagem 1 %32 HP Pavilion dv7-1448dx RAM Replacement, RAM: passo 4, imagem 2 %32 HP Pavilion dv7-1448dx RAM Replacement, RAM: passo 4, imagem 3 %32
    • Remove the six Phillips PM2.5X6.0 screws with a Phillips #00 screwdriver.
    • Pry the back casing up and away from the rest of the laptop with the plastic opening tool.
  5. HP Pavilion dv7-1448dx RAM Replacement: passo 5, imagem 1 %32 HP Pavilion dv7-1448dx RAM Replacement: passo 5, imagem 2 %32 HP Pavilion dv7-1448dx RAM Replacement: passo 5, imagem 3 %32
    • Remove the green RAM by prying it upward and pulling it away from its slot.
Conclusão
Kirsten Gilliland
Membro desde: 01/30/17
741 Reputação
Autoria de 4 guias
Equipe
Baylor, Team 3-5, Whitney Spring 2017 Membro de Baylor, Team 3-5, Whitney Spring 2017
BU-WHITNEY-S17S3G5
Membros da 2
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 315
