Ir para o conteúdo principal
HP Pavilion dv7-1448dx Battery Replacement
  1. HP Pavilion dv7-1448dx Battery Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the computer is unplugged and turned off.
    • Place the computer front side down with the battery compartment farthest away.
  2. HP Pavilion dv7-1448dx Battery Replacement: passo 2, imagem 1 %32 HP Pavilion dv7-1448dx Battery Replacement: passo 2, imagem 2 %32
    • Slide the switch under the battery compartment to the left until the compartment opens. This may require some force.
  3. HP Pavilion dv7-1448dx Battery Replacement: passo 3, imagem 1 %32 HP Pavilion dv7-1448dx Battery Replacement: passo 3, imagem 2 %32
    • Lightly pry the battery upward to remove.
    • When reinserting the battery, match the latches along the backside of the battery with the corresponding slots in the computer in order to press it into place.
Conclusão
To reinsert a new battery, follow these instructions in reverse order.
Kirsten Gilliland
Membro desde: 01/30/17
741 Reputação
Autoria de 4 guias
Equipe
Baylor, Team 3-5, Whitney Spring 2017 Membro de Baylor, Team 3-5, Whitney Spring 2017
BU-WHITNEY-S17S3G5
Membros da 2
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 237
