Ir para o conteúdo principal
HP Pavilion dv7-1285dx Wifi Card Replacement
O que você precisa
  1. HP Pavilion dv7-1285dx Wifi Card Replacement, Battery: passo 1, imagem 1 %32
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx Wifi Card Replacement, Back Plate: passo 2, imagem 1 %32
    • Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
    • These screws do not completely detach from the device when unscrewed.
  3. HP Pavilion dv7-1285dx Wifi Card Replacement: passo 3, imagem 1 %32 HP Pavilion dv7-1285dx Wifi Card Replacement: passo 3, imagem 2 %32
    • Use the plastic opening tool to lift up the back plate and set it aside.
  4. HP Pavilion dv7-1285dx Wifi Card Replacement, Wifi Card: passo 4, imagem 1 %32
    • Locate the wifi card to the right of the RAM.
  5. HP Pavilion dv7-1285dx Wifi Card Replacement: passo 5, imagem 1 %32
    • Unplug antenna cables 1 and 2 from their leads.
    • Antenna cable 3 is not used.
  6. HP Pavilion dv7-1285dx Wifi Card Replacement: passo 6, imagem 1 %32
    • Remove the two Phillips head screws located on the battery compartment side of the wifi card.
  7. HP Pavilion dv7-1285dx Wifi Card Replacement: passo 7, imagem 1 %32
    • Gently lift the wifi card up to a 45 degree angle from the side with screws.
  8. HP Pavilion dv7-1285dx Wifi Card Replacement: passo 8, imagem 1 %32 HP Pavilion dv7-1285dx Wifi Card Replacement: passo 8, imagem 2 %32
    • Unplug the wifi card.
  9. HP Pavilion dv7-1285dx Wifi Card Replacement: passo 9, imagem 1 %32
    • These next steps are for installing your replacement wifi card. These steps are very important to ensure that you do not damage your device.
    • Fully insert the replacement wifi card at a 45 degree angle, ensuring that the notch on the card lines up with the peg on the plug.
  10. HP Pavilion dv7-1285dx Wifi Card Replacement: passo 10, imagem 1 %32
    • Gently push the wifi card down until the screws can be replaced.
  11. HP Pavilion dv7-1285dx Wifi Card Replacement: passo 11, imagem 1 %32
    • Connect the antenna cable 1 with lead 1 and connect antenna cable 2 with lead 2.
    • Wire 1 needs to be connected to lead 1 and wire 2 needs to be connected to lead 2.
    • Wire 3 and lead 3 are not used.
Conclusão
Anmol Mathur
Membro desde: 04/14/14
291 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 12-34, Maness Spring 2014 Membro de Cal Poly, Team 12-34, Maness Spring 2014
CPSU-MANESS-S14S12G34
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 2,135
