Ir para o conteúdo principal
HP Pavilion dv7-1285dx Back Plate Replacement
O que você precisa
  1. HP Pavilion dv7-1285dx Back Plate Replacement, Battery: passo 1, imagem 1 %32
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx Back Plate Replacement, Back Plate: passo 2, imagem 1 %32
    • Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
    • These screws do not completely detach from the device when unscrewed.
  3. HP Pavilion dv7-1285dx Back Plate Replacement: passo 3, imagem 1 %32 HP Pavilion dv7-1285dx Back Plate Replacement: passo 3, imagem 2 %32
    • Use the plastic opening tool to lift up the back plate and set it aside.
Conclusão
Chris Apple
Membro desde: 04/14/14
239 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 12-34, Maness Spring 2014 Membro de Cal Poly, Team 12-34, Maness Spring 2014
CPSU-MANESS-S14S12G34
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 1,526
