Ir para o conteúdo principal
HP Pavilion dv6700 Display/Monitor Replacement
O que você precisa
  1. HP Pavilion dv6700 Display/Monitor Replacement, Battery: passo 1, imagem 1 %32
    • Flip over the device so that the bottom is facing you.
    • Locate the battery on the bottom of your laptop.
  2. HP Pavilion dv6700 Display/Monitor Replacement: passo 2, imagem 1 %32 HP Pavilion dv6700 Display/Monitor Replacement: passo 2, imagem 2 %32
    • Slide the tab all the way over to the left until battery pops out. Lift out and remove battery.
  3. HP Pavilion dv6700 Display/Monitor Replacement, Display/Monitor: passo 3, imagem 1 %32 HP Pavilion dv6700 Display/Monitor Replacement, Display/Monitor: passo 3, imagem 2 %32
    • Remove the RAM port cover by unscrewing the two screws.
    • These screws can not be fully removed because they’re captive. Loosen them until they turn freely.
  4. HP Pavilion dv6700 Display/Monitor Replacement: passo 4, imagem 1 %32 HP Pavilion dv6700 Display/Monitor Replacement: passo 4, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the two screws securing Hard Disk Drive (HDD) cover.
    • Screws will not fully remove. Loosen them until they turn freely.
  5. HP Pavilion dv6700 Display/Monitor Replacement: passo 5, imagem 1 %32 HP Pavilion dv6700 Display/Monitor Replacement: passo 5, imagem 2 %32 HP Pavilion dv6700 Display/Monitor Replacement: passo 5, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove the 25 screws securing the bottom of the computer.
  6. HP Pavilion dv6700 Display/Monitor Replacement: passo 6, imagem 1 %32 HP Pavilion dv6700 Display/Monitor Replacement: passo 6, imagem 2 %32 HP Pavilion dv6700 Display/Monitor Replacement: passo 6, imagem 3 %32
    • Detach WiFi antenna wires.
    • Be sure that the wires are labeled so you remember which ones go where.
  7. HP Pavilion dv6700 Display/Monitor Replacement: passo 7, imagem 1 %32 HP Pavilion dv6700 Display/Monitor Replacement: passo 7, imagem 2 %32 HP Pavilion dv6700 Display/Monitor Replacement: passo 7, imagem 3 %32
    • Using the Phillips #0 screwdriver remove the 2 screws.
    • Use a needle-nose pliers to do the initial loosening, then switch to using a hex screwdriver (size 5) head to do the rest of the loosening.
  8. HP Pavilion dv6700 Display/Monitor Replacement: passo 8, imagem 1 %32 HP Pavilion dv6700 Display/Monitor Replacement: passo 8, imagem 2 %32
    • Flip over HP Pavilion dv6700 so that the top is facing you.
    • Open up HP Pavilion dv6700.
  9. HP Pavilion dv6700 Display/Monitor Replacement: passo 9, imagem 1 %32 HP Pavilion dv6700 Display/Monitor Replacement: passo 9, imagem 2 %32 HP Pavilion dv6700 Display/Monitor Replacement: passo 9, imagem 3 %32
    • Use an iFixit opening tool to pry open the plastic bar above the keyboard.
    • Be careful not to yank so hard that you rip out the ribbon cables underneath. There is enough room to pull safely, but use control to prevent damage.
  10. HP Pavilion dv6700 Display/Monitor Replacement: passo 10, imagem 1 %32 HP Pavilion dv6700 Display/Monitor Replacement: passo 10, imagem 2 %32 HP Pavilion dv6700 Display/Monitor Replacement: passo 10, imagem 3 %32
    • Pull out and up on keyboard to remove it.
    • Do not yank it all of the way out, as there is a ribbon cable underneath.
    • Slide the two black locks on the side of the keyboard cable connection port up to release the cable.
    • Grip the ribbon cable near the connection point and gently but firmly pull it out.
  11. HP Pavilion dv6700 Display/Monitor Replacement: passo 11, imagem 1 %32 HP Pavilion dv6700 Display/Monitor Replacement: passo 11, imagem 2 %32
    • Flip over the plastic bar.
    • Detach the display connector.
    • Do not pull on the wires. Pull on the black plastic part or wedge an iFixit opening tool or fingernail between the port and the connector.
  12. HP Pavilion dv6700 Display/Monitor Replacement: passo 12, imagem 1 %32 HP Pavilion dv6700 Display/Monitor Replacement: passo 12, imagem 2 %32 HP Pavilion dv6700 Display/Monitor Replacement: passo 12, imagem 3 %32
    • Detach the ribbon cables.
    • Pull from the area closest to the connection port gently but firmly.
  13. HP Pavilion dv6700 Display/Monitor Replacement: passo 13, imagem 1 %32 HP Pavilion dv6700 Display/Monitor Replacement: passo 13, imagem 2 %32 HP Pavilion dv6700 Display/Monitor Replacement: passo 13, imagem 3 %32
    • Pull up on tape holding down wires.
  14. HP Pavilion dv6700 Display/Monitor Replacement: passo 14, imagem 1 %32 HP Pavilion dv6700 Display/Monitor Replacement: passo 14, imagem 2 %32 HP Pavilion dv6700 Display/Monitor Replacement: passo 14, imagem 3 %32
    • Pull up on the WiFi wires and out from under the metal tabs.
    • Do not yank them out. Let them hang loose once they are out from under the tabs.
  15. HP Pavilion dv6700 Display/Monitor Replacement: passo 15, imagem 1 %32 HP Pavilion dv6700 Display/Monitor Replacement: passo 15, imagem 2 %32 HP Pavilion dv6700 Display/Monitor Replacement: passo 15, imagem 3 %32
    • Disconnect the connector from the port.
    • Remove the wire from under the metal tabs.
    • Let wire hang loose after removing under the tabs.
  16. HP Pavilion dv6700 Display/Monitor Replacement: passo 16, imagem 1 %32 HP Pavilion dv6700 Display/Monitor Replacement: passo 16, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the black screw located in the top right corner near the display.
  17. HP Pavilion dv6700 Display/Monitor Replacement: passo 17, imagem 1 %32 HP Pavilion dv6700 Display/Monitor Replacement: passo 17, imagem 2 %32
    • Pull upward on the screen connector tab.
    • It will be firmly secured, so don't be afraid to use a little extra force to pull it off.
  18. HP Pavilion dv6700 Display/Monitor Replacement: passo 18, imagem 1 %32 HP Pavilion dv6700 Display/Monitor Replacement: passo 18, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the black screw securing the screen.
    • Keep your hand on the screen to secure it, as once you remove this screw, it will come loose.
    • Lift the screen off and set it aside.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 2,114
