Ir para o conteúdo principal
HP Pavilion dv6500 Speaker Replacement
O que você precisa
  1. HP Pavilion dv6500 Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Remove all 4 of the 7.0mm screws and the 3 silver, smaller 4.0mm screws inside the cavity of the battery
  2. HP Pavilion dv6500 Speaker Replacement: passo 2, imagem 1 %32 HP Pavilion dv6500 Speaker Replacement: passo 2, imagem 2 %32
    • Gently lift the plastic panel on the top of the laptop at the divide until the two ribbon cables and cable leads are visible with their ports on left side on laptop.
  3. HP Pavilion dv6500 Speaker Replacement: passo 3, imagem 1 %32
    • Gently pull on the 2 ribbon cables until they detach from the computer.
    • Unplug cables connecting the top keyboard assembly and computer body.
    • Be careful not to rip the speaker cables.
Conclusão
Andrew
Membro desde: 10/23/16
392 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 1-6, Catania Fall 2016 Membro de UMass Dartmouth, Team 1-6, Catania Fall 2016
UMASSD-CATANIA-F16S1G6
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 765
