Ir para o conteúdo principal
HP Pavilion dv6000 Speaker Bar Replacement
O que você precisa
  1. HP Pavilion dv6000 Speaker Bar Replacement, Speaker Bar: passo 1, imagem 1 %32
    • Make sure the laptop lid is closed, turn it over and remove the battery by moving the switch right to left.
    • there are three philips screws located on the surface where the writing is. remove those three screws.
  2. HP Pavilion dv6000 Speaker Bar Replacement: passo 2, imagem 1 %32
    • turn the laptop right side up. Between the cover and case on the top right of the laptop and using a plastic sludger or a finger lift gently on the speaker cover as to disengage the clips.
    • Be sure not to pull hard or you may damage the ribbon cables.
    • From the side closest to the screen turn the cover towards yourself.
  3. HP Pavilion dv6000 Speaker Bar Replacement: passo 3, imagem 1 %32
    • there is one connector from the speaker bar to a control board. Gently remove the cable.
    • There are two more screws attaching the speaker bar to the cover, remove these and take the speaker bar out.
  4. HP Pavilion dv6000 Speaker Bar Replacement: passo 4, imagem 1 %32
    • you are now ready to replace or repair the speaker bar. I recomend purchasing a new one, they range anywhere from 5-15 dollars online.
Conclusão
5 outras pessoas executaram este guia.
Joba Fett
Membro desde: 04/11/14
227 Reputação
Autoria de 1 guia
2 comentários
how to fix speaker from board
kingsley Osunkwo - Responder
Grazie siete bravissimi . Ce ne fossero persone come voi che altruisticamente mettono a disposizione la loro esperienza di riparazioni per gli altri!
Fernando Mancini
fernando mancini - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 3,333
