Ir para o conteúdo principal
HP Pavilion dv6000 Optical Drive Replacement
O que você precisa
  1. HP Pavilion dv6000 Optical Drive Replacement, Optical Drive: passo 1, imagem 1 %32
    • Before proceeding, it is recommended to remove the battery to prevent any electrical damage to components.
    • Remove the single 5.6 mm Phillips screw securing the optical drive to the lower case.
  2. HP Pavilion dv6000 Optical Drive Replacement: passo 2, imagem 1 %32
    • Insert the tip of an unrolled paper clip into the small hole located on the side of the optical drive.
    • The tray will partially pop out of the laptop.
    • Firmly pull the drive straight away from the laptop.
    • While pulling the drive out, be careful not to bend the sliding rails on both sides of the optical drive.
    • At this point you can remove the entire optical drive, or you can continue to disassemble the optical drive assembly.
Conclusão
6 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 8,181
