Ir para o conteúdo principal
HP Pavilion dv6000 LCD Screen Replacement
O que você precisa
  1. HP Pavilion dv6000 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32 HP Pavilion dv6000 LCD Screen Replacement, LCD Screen: passo 1, imagem 2 %32
    • Remove rubber screw covers from the LCD screen. The top covers pop off with a fingernail but the two on the bottom may require a screwdriver or flat tool.
    • Remove the six 7.15mm screws underneath the stoppers. There are four on top and two on bottom.
  2. HP Pavilion dv6000 LCD Screen Replacement: passo 2, imagem 1 %32 HP Pavilion dv6000 LCD Screen Replacement: passo 2, imagem 2 %32
    • Press the tabs on the sides of the screen in and pop the plastic off. Careful, the plastic is very flimsy and may break.
  3. HP Pavilion dv6000 LCD Screen Replacement: passo 3, imagem 1 %32 HP Pavilion dv6000 LCD Screen Replacement: passo 3, imagem 2 %32
    • Remove the two screws (5.8mm) on either side of the LCD near the hinge. Remove the screws on the outermost side first.
  4. HP Pavilion dv6000 LCD Screen Replacement: passo 4, imagem 1 %32 HP Pavilion dv6000 LCD Screen Replacement: passo 4, imagem 2 %32
    • Take out the two 3.58mm screws on the LCD at the top (one on each edge).
  5. HP Pavilion dv6000 LCD Screen Replacement: passo 5, imagem 1 %32
    • Hold on to the LCD screen to prevent it from falling over and remove the two 3.58mm screws on the sides at the bottom.
  6. HP Pavilion dv6000 LCD Screen Replacement: passo 6, imagem 1 %32 HP Pavilion dv6000 LCD Screen Replacement: passo 6, imagem 2 %32 HP Pavilion dv6000 LCD Screen Replacement: passo 6, imagem 3 %32
    • Let the screen gently rest on the keyboard.
    • Remove the tape from the ribbon.
    • Stop here and check the cable
Conclusão
15 outras pessoas executaram este guia.
Ben Hirsch
Membro desde: 10/05/10
3.841 Reputação
Autoria de 10 guias
Equipe
Cal Poly, Team 21-33, Regan Fall 2010 Membro de Cal Poly, Team 21-33, Regan Fall 2010
CPSU-REGAN-F10S21G33
4 Membros
Autoria de 12 guias
Um comentário
after replacing my cracked screen the back light does not show again
firelionkofi - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 16
Ao todo: 39,462
