Introdução
If the camera on your HP Pavilion dv6000 needs to be repaired, follow this guide.
Ferramentas
Peças
Nenhum componente especificado.
Remove rubber screw covers from the LCD screen. They cover the screws. The stops on the top of the screen pop off, but the lower covers require a screwdriver to remove.
If you need to use the screwdriver to remove the rubber screw covers, gently push the screwdriver down the edge of the stopper and then use the screwdriver as a lever to pry the cover from the hole.
Remove the six 7.15mm screws underneath the stoppers. There are four on top and two on bottom.
3 outras pessoas concluíram este guia.
