Ir para o conteúdo principal
HP Pavilion dv6-6117dx RAM Replacement
O que você precisa
  1. HP Pavilion dv6-6117dx RAM Replacement, RAM: passo 1, imagem 1 %32 HP Pavilion dv6-6117dx RAM Replacement, RAM: passo 1, imagem 2 %32
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx RAM Replacement: passo 2, imagem 1 %32 HP Pavilion dv6-6117dx RAM Replacement: passo 2, imagem 2 %32
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx RAM Replacement: passo 3, imagem 1 %32 HP Pavilion dv6-6117dx RAM Replacement: passo 3, imagem 2 %32 HP Pavilion dv6-6117dx RAM Replacement: passo 3, imagem 3 %32
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx RAM Replacement: passo 4, imagem 1 %32 HP Pavilion dv6-6117dx RAM Replacement: passo 4, imagem 2 %32
    • Push the tabs on both sides away from each other to free the RAM, which will raise to a 45º angle.
  5. HP Pavilion dv6-6117dx RAM Replacement: passo 5, imagem 1 %32 HP Pavilion dv6-6117dx RAM Replacement: passo 5, imagem 2 %32
    • Always handle RAM by the edges to avoid damaging the part.
    • Remove the RAM by grabbing it by the sides and pulling out at a 45º angle.
    • When inserting the new stick of RAM, you should insert it at this same angle.
Conclusão
Joshua Holme
Membro desde: 03/19/18
765 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 6
Últimos 30 dias: 22
Duração total: 737
