Ir para o conteúdo principal
HP Pavilion dv6-6117dx Optical Drive Replacement
O que você precisa
  1. HP Pavilion dv6-6117dx Optical Drive Replacement, Optical Drive: passo 1, imagem 1 %32 HP Pavilion dv6-6117dx Optical Drive Replacement, Optical Drive: passo 1, imagem 2 %32
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx Optical Drive Replacement: passo 2, imagem 1 %32 HP Pavilion dv6-6117dx Optical Drive Replacement: passo 2, imagem 2 %32
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx Optical Drive Replacement: passo 3, imagem 1 %32 HP Pavilion dv6-6117dx Optical Drive Replacement: passo 3, imagem 2 %32 HP Pavilion dv6-6117dx Optical Drive Replacement: passo 3, imagem 3 %32
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx Optical Drive Replacement: passo 4, imagem 1 %32 HP Pavilion dv6-6117dx Optical Drive Replacement: passo 4, imagem 2 %32 HP Pavilion dv6-6117dx Optical Drive Replacement: passo 4, imagem 3 %32
    • Using a Phillips #0 screw driver, remove the single 4mm screw holding the optical drive in place
  5. HP Pavilion dv6-6117dx Optical Drive Replacement: passo 5, imagem 1 %32 HP Pavilion dv6-6117dx Optical Drive Replacement: passo 5, imagem 2 %32 HP Pavilion dv6-6117dx Optical Drive Replacement: passo 5, imagem 3 %32
    • Using a plastic spudger, push the optical drive out toward the left of the device
Conclusão
Joshua Holme
Membro desde: 03/19/18
765 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 306
