Ir para o conteúdo principal
HP Pavilion dv6-6117dx Hard Drive Replacement
O que você precisa
  1. HP Pavilion dv6-6117dx Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32 HP Pavilion dv6-6117dx Hard Drive Replacement, Hard Drive: passo 1, imagem 2 %32
    • Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
  2. HP Pavilion dv6-6117dx Hard Drive Replacement: passo 2, imagem 1 %32 HP Pavilion dv6-6117dx Hard Drive Replacement: passo 2, imagem 2 %32
    • Slide a black spudger under the top of the cover to loosen the clips underneath.
  3. HP Pavilion dv6-6117dx Hard Drive Replacement: passo 3, imagem 1 %32 HP Pavilion dv6-6117dx Hard Drive Replacement: passo 3, imagem 2 %32 HP Pavilion dv6-6117dx Hard Drive Replacement: passo 3, imagem 3 %32
    • Slide the spudger down the left side of the cover to loosen the clips.
    • After the left side is loose, the rest of the cover should pop off, and you can remove it with your hands.
    • When reassembling, insert the bottom of the cover first, and then firmly press along the edges from bottom to top to secure it in place.
  4. HP Pavilion dv6-6117dx Hard Drive Replacement: passo 4, imagem 1 %32 HP Pavilion dv6-6117dx Hard Drive Replacement: passo 4, imagem 2 %32 HP Pavilion dv6-6117dx Hard Drive Replacement: passo 4, imagem 3 %32
    • Using a Phillips #0 screw driver, remove the four 4mm screws holding the hard drive in place.
  5. HP Pavilion dv6-6117dx Hard Drive Replacement: passo 5, imagem 1 %32 HP Pavilion dv6-6117dx Hard Drive Replacement: passo 5, imagem 2 %32 HP Pavilion dv6-6117dx Hard Drive Replacement: passo 5, imagem 3 %32
    • Using a plastic spudger, lift up the hard drive from the top left corner and flip it to the right of the laptop like opening a book.
    • There is a cable connecting the hard drive to the laptop, be sure not to pull it out when flipping the hard drive.
  6. HP Pavilion dv6-6117dx Hard Drive Replacement: passo 6, imagem 1 %32 HP Pavilion dv6-6117dx Hard Drive Replacement: passo 6, imagem 2 %32
    • Pull the tab at the end of the cable connecting the hard drive to the laptop.
  7. HP Pavilion dv6-6117dx Hard Drive Replacement: passo 7, imagem 1 %32 HP Pavilion dv6-6117dx Hard Drive Replacement: passo 7, imagem 2 %32 HP Pavilion dv6-6117dx Hard Drive Replacement: passo 7, imagem 3 %32
    • Using a Phillips #0 screw driver, remove the four 4mm screws on each side of the hard drive attaching it to its carriage.
  8. HP Pavilion dv6-6117dx Hard Drive Replacement: passo 8, imagem 1 %32 HP Pavilion dv6-6117dx Hard Drive Replacement: passo 8, imagem 2 %32
    • Remove the hard drive from its carriage.
  9. HP Pavilion dv6-6117dx Hard Drive Replacement: passo 9, imagem 1 %32 HP Pavilion dv6-6117dx Hard Drive Replacement: passo 9, imagem 2 %32
    • Remove the SATA cable from the hard drive.
Conclusão
4 outras pessoas executaram este guia.
Joshua Holme
Membro desde: 03/19/18
765 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 11
Últimos 30 dias: 44
Duração total: 2,536
