Introdução
Is your computer out of storage? Maybe you want to make your computer faster. Replacing the hard drive with a Solid State Drive (SSD) will help make your computer run faster, while also giving you more storage if you get a larger one. This guide will walk you through replacing your hard drive with another hard drive or SSD. Grab a spudger, a Phillips #0 screw driver and a clean work space, then follow the steps below.
O que você precisa
Begin removing the bottom cover by sliding the battery removal slider to the right to pop off the top of the cover.
4 outras pessoas executaram este guia.
