Introdução
The random access memory (RAM) stores temporary data for programs to use while they are running. Some programs use a lot of memory so it may be useful to replace RAM with ones with more memory on them.
O que você precisa
Locate the battery on the bottom side of the laptop.
Slide the release switch and the battery will pop out.
Remove the battery
Using the Phillips #1, loosen the three 7mm captive screws that secure the memory module cover to the computer.
Uma outra pessoa concluiu este guia.
