Ir para o conteúdo principal
HP Pavilion dv6-2158nr Keyboard Replacement
O que você precisa
  1. HP Pavilion dv6-2158nr Keyboard Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion dv6-2158nr Keyboard Replacement, Battery: passo 1, imagem 2 %32 HP Pavilion dv6-2158nr Keyboard Replacement, Battery: passo 1, imagem 3 %32
    • Locate the battery on the bottom side of the laptop.
    • Slide the release switch and the battery will pop out.
    • Remove the battery
  2. HP Pavilion dv6-2158nr Keyboard Replacement, Keyboard: passo 2, imagem 1 %32 HP Pavilion dv6-2158nr Keyboard Replacement, Keyboard: passo 2, imagem 2 %32 HP Pavilion dv6-2158nr Keyboard Replacement, Keyboard: passo 2, imagem 3 %32
    • Using a Philips #1 Loosen the three 7mm captive screws that secure the memory module compartment cover to the computer.
    • Lift the rear edge of the cover, swing it up and to the front, and remove the cover.
  3. HP Pavilion dv6-2158nr Keyboard Replacement: passo 3, imagem 1 %32 HP Pavilion dv6-2158nr Keyboard Replacement: passo 3, imagem 2 %32
    • Loosen the two 6mm captive screws that secure the hard drive port bezel cover to the computer, using a Philips #1.
    • Lift the right side of the hard drive port bezel cover, swing it up and to the left, and remove the cover.
  4. HP Pavilion dv6-2158nr Keyboard Replacement: passo 4, imagem 1 %32 HP Pavilion dv6-2158nr Keyboard Replacement: passo 4, imagem 2 %32 HP Pavilion dv6-2158nr Keyboard Replacement: passo 4, imagem 3 %32
    • Use the Mylar tab to lift the hard drive up, and then slide it to the left to release it from the hard drive bay.
  5. HP Pavilion dv6-2158nr Keyboard Replacement: passo 5, imagem 1 %32 HP Pavilion dv6-2158nr Keyboard Replacement: passo 5, imagem 2 %32
    • Disconnect the hard drive cable from the system board.
    • Remove the hard drive from the hard drive bay and set it aside.
  6. HP Pavilion dv6-2158nr Keyboard Replacement: passo 6, imagem 1 %32 HP Pavilion dv6-2158nr Keyboard Replacement: passo 6, imagem 2 %32
    • With laptop upside down locate the three sets of screws that fasten the keyboard and switch cover.
    • Two Phillips 7mm screws that secure the switch cover to the computer.
    • Four Phillips 4.0mm screws that secure the switch cover to the computer. (these are inside the battery bay)
    • Four Philips 7mm screws that secure the keyboard to the computer.
    • Remove all ten screws.
  7. HP Pavilion dv6-2158nr Keyboard Replacement: passo 7, imagem 1 %32 HP Pavilion dv6-2158nr Keyboard Replacement: passo 7, imagem 2 %32
    • Turn the computer over, and locate the Switch Cover.
    • Using the Safe Pry Tool, un-clip the Switch Cover until it detaches from the computer.
    • The clips will need careful prying to unhook.
  8. HP Pavilion dv6-2158nr Keyboard Replacement: passo 8, imagem 1 %32 HP Pavilion dv6-2158nr Keyboard Replacement: passo 8, imagem 2 %32 HP Pavilion dv6-2158nr Keyboard Replacement: passo 8, imagem 3 %32
    • Slide the Switch Cover onto the LCD Monitor, exposing the Speaker Assembly.
    • There are two ribbon cables still attached to the speaker assembly
    • Detach the two ribbon cables from the speaker assembly.
  9. HP Pavilion dv6-2158nr Keyboard Replacement: passo 9, imagem 1 %32 HP Pavilion dv6-2158nr Keyboard Replacement: passo 9, imagem 2 %32 HP Pavilion dv6-2158nr Keyboard Replacement: passo 9, imagem 3 %32
    • Remove the three silver Phillips 3.5mm screws that secure the keyboard to the computer.
    • Lift the rear edge of the keyboard and slide the keyboard back until the keyboard connector on the system board is accessible.
  10. HP Pavilion dv6-2158nr Keyboard Replacement: passo 10, imagem 1 %32 HP Pavilion dv6-2158nr Keyboard Replacement: passo 10, imagem 2 %32 HP Pavilion dv6-2158nr Keyboard Replacement: passo 10, imagem 3 %32
    • Unhinge the zero insertion force (ZIF) connector to release the ribbon cable then pull gently on the cable to release.
    • You need to unhinge the blue plastic to release the ribbon cable from the main board.
    • The keyboard can now be lifted off and set aside.
Conclusão
6 outras pessoas executaram este guia.
Chad
Membro desde: 01/13/14
1.123 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 10-34, Maness Winter 2014 Membro de Cal Poly, Team 10-34, Maness Winter 2014
CPSU-MANESS-W14S10G34
Membros da 4
Autoria de 6 guias
Um comentário
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 21
Duração total: 5,680
