Ir para o conteúdo principal
HP Pavilion dv5000 RAM Replacement
O que você precisa
  1. HP Pavilion dv5000 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the computer, and unplug it from all external power sources.
    • Lay the computer face-down on a flat surface. Orient the computer to match the image.
    • Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
  2. HP Pavilion dv5000 RAM Replacement, RAM Cover: passo 2, imagem 1 %32 HP Pavilion dv5000 RAM Replacement, RAM Cover: passo 2, imagem 2 %32 HP Pavilion dv5000 RAM Replacement, RAM Cover: passo 2, imagem 3 %32
    • Remove the two 5mm Phillips screws on the right side of the RAM cover.
    • Lift the right side of the RAM cover, and remove it.
  3. HP Pavilion dv5000 RAM Replacement, RAM: passo 3, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Release the RAM by pressing the metal heads of the RAM clips to the sides. Use tweezers and the spudger to spread the clips until they are completely off the RAM.
    • There are two RAM cards in this device.
  4. HP Pavilion dv5000 RAM Replacement: passo 4, imagem 1 %32 HP Pavilion dv5000 RAM Replacement: passo 4, imagem 2 %32 HP Pavilion dv5000 RAM Replacement: passo 4, imagem 3 %32
    • Remove the RAM.
  5. HP Pavilion dv5000 RAM Replacement: passo 5, imagem 1 %32
    • As in step 3, press the clips on both sides to release the second RAM clip.
  6. HP Pavilion dv5000 RAM Replacement: passo 6, imagem 1 %32 HP Pavilion dv5000 RAM Replacement: passo 6, imagem 2 %32 HP Pavilion dv5000 RAM Replacement: passo 6, imagem 3 %32
    • Remove the RAM.
Conclusão
Thanh Nguyen
Membro desde: 10/05/10
414 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 21-34, Regan Fall 2010 Membro de Cal Poly, Team 21-34, Regan Fall 2010
CPSU-REGAN-F10S21G34
Membros da 4
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 15,069
