Ir para o conteúdo principal
Peças
Nenhum componente especificado.
  1. Este passo não foi traduzido. Ajude a traduzi-lo
    Turn off the computer, and unplug it from all external power sources.
    • Turn off the computer, and unplug it from all external power sources.
    • Lay the computer face-down on a flat surface. Orient the computer to match the image.
    • Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
  2. Este passo não foi traduzido. Ajude a traduzi-lo
    Remove the two 11.0mm screws at the corners on either side of the battery compartment.
    • Remove the two 11.0mm screws at the corners on either side of the battery compartment.
    • Remove the three 6.0mm screws.
    • Remove the two 5.0mm screws.
    • Remove the 6.0mm screw in the middle of the battery compartment.
  3. Este passo não foi traduzido. Ajude a traduzi-lo
    Turn the computer over and open the screen. This provides access to the screen hinges.
    • Turn the computer over and open the screen. This provides access to the screen hinges.
    • The keyboard switch cover is attached to the computer with a series of snaps. With a flathead screwdriver, pry up the switch cover until it pops free.
  4. Este passo não foi traduzido. Ajude a traduzi-lo
    Be careful not to bend the keyboard switch cover too far when removing it.
    • Be careful not to bend the keyboard switch cover too far when removing it.
  5. Este passo não foi traduzido. Ajude a traduzi-lo
    Next, remove the keyboard. Push on the keyboard frame above the function keys and slide the keyboard toward the screen.
    • Next, remove the keyboard. Push on the keyboard frame above the function keys and slide the keyboard toward the screen.
  6. Este passo não foi traduzido. Ajude a traduzi-lo
    Carefully lift the trackpad-side edge of the keyboard to reveal the LED and keyboard cable connectors. Detach the cable connectors from the computer by gripping each cable connector close to the computer contact point and pulling up gently.
    • Carefully lift the trackpad-side edge of the keyboard to reveal the LED and keyboard cable connectors.
    • Detach the cable connectors from the computer by gripping each cable connector close to the computer contact point and pulling up gently.
  7. Este passo não foi traduzido. Ajude a traduzi-lo
    This step is for replacing the keyboard only. If you are not replacing the keyboard, skip this step.
    • This step is for replacing the keyboard only. If you are not replacing the keyboard, skip this step.
    • Lay the keyboard face down.
    • Remove the four 3.00mm screws that attach the keyboard to the keyboard frame.
  8. Este passo não foi traduzido. Ajude a traduzi-lo
    • Lift the keyboard off the keyboard frame.
Linha de Chegada
6 outras pessoas concluíram este guia.
Alex Kwok
Membro desde: 05/10/2010
268 Reputação
3 Guias de autoria
Equipe
Cal Poly, Team 21-34, Regan Fall 2010 Membro de Cal Poly, Team 21-34, Regan Fall 2010
CPSU-REGAN-F10S21G34
4 Membros
11 Guias de autoria
Hey is keyboard replacement same or very similiar procedure with hp dv8000?
Arkadiusz Gąsior - Responder
Brilliant. This is the best tutorial out there. Many thanks indeed!!!!
stevefranklin75 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 10,968
