O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Lay the computer face-down on a flat surface. Orient the computer to match the image.
Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
Locate the hard drive cover. Note that in this image, the RAM cover is still in place.
Remove the two screws securing the hard drive cover.
Remove the two 5.0mm screws securing the hard drive bracket.
Slide the hard drive to the right until the edge of the hard drive is flush with the computer frame.
Lift the hard drive out of the hard drive bay, left side first.
2 outras pessoas concluíram este guia.
