Ir para o conteúdo principal
HP Pavilion dv4000 Hard Drive Replacement
O que você precisa
  1. HP Pavilion dv4000 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop upside down with the battery compartment facing you.
  2. HP Pavilion dv4000 Hard Drive Replacement: passo 2, imagem 1 %32
    • Slide the battery release latch to the right and hold in place.
  3. HP Pavilion dv4000 Hard Drive Replacement: passo 3, imagem 1 %32
    • Lift the front edge of the battery up and remove it from the compartment.
  4. HP Pavilion dv4000 Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32
    • Orient the laptop with the hard drive panel towards you.
  5. HP Pavilion dv4000 Hard Drive Replacement: passo 5, imagem 1 %32
    • Unscrew the two 2x5mm screws with a #00 Phillips screwdriver.
  6. HP Pavilion dv4000 Hard Drive Replacement: passo 6, imagem 1 %32 HP Pavilion dv4000 Hard Drive Replacement: passo 6, imagem 2 %32
    • Lift the cover up by the tab near the screws.
    • The cover can be removed from the laptop.
  7. HP Pavilion dv4000 Hard Drive Replacement: passo 7, imagem 1 %32
    • Grab the hard drive from the sides and slide it away from the connectors.
    • The hard drive should disconnect with light force. If it doesn't easily slide out, ensure there are no cables or obstacles preventing it from moving.
    • Lift and remove the hard drive from the laptop.
    • We did not have a hard drive in our laptop to demonstrate how to remove it.
Conclusão
To replace the hard drive, follow these instructions in reverse.
Uma outra pessoa concluiu este guia.
Chris Marshall
Membro desde: 10/18/16
454 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 4-2, Catania Fall 2016 Membro de UMass Dartmouth, Team 4-2, Catania Fall 2016
UMASSD-CATANIA-F16S4G2
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 23
Duração total: 1,829
