Ir para o conteúdo principal
HP Pavilion dv2913cl WiFi receiver Replacement
O que você precisa
  1. HP Pavilion dv2913cl WiFi receiver Replacement, WiFi receiver: passo 1, imagem 1 %32
    • Begin by locating the smallest panel with one screw attaching it to the laptop computer.
  2. HP Pavilion dv2913cl WiFi receiver Replacement: passo 2, imagem 1 %32
    • Remove the one screw holding the panel down, and the WiFi receiver will be revealed.
  3. HP Pavilion dv2913cl WiFi receiver Replacement: passo 3, imagem 1 %32
    • Remove the two screws that hold down the receiver.
    • Gently slide the chip out of the socket.
  4. HP Pavilion dv2913cl WiFi receiver Replacement: passo 4, imagem 1 %32 HP Pavilion dv2913cl WiFi receiver Replacement: passo 4, imagem 2 %32
    • Remove the two wires labelled AUX and MAIN from the chip.
    • Remember where these were attached previously as it is important for proper functionality after the replacement.
Conclusão
Adam Braga
Membro desde: 10/24/16
230 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 2-7, Isaacson Fall 2016 Membro de UMass Dartmouth, Team 2-7, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G7
3 Membros
Autoria de 4 guias
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 140
