Ir para o conteúdo principal
HP Pavilion dv2913cl RAM Replacement
O que você precisa
  1. HP Pavilion dv2913cl RAM  Replacement, Ram: passo 1, imagem 1 %32 HP Pavilion dv2913cl RAM  Replacement, Ram: passo 1, imagem 2 %32
    • Unscrew the two screws on the center panel of the device .
    • Then gently remove the center panel.
  2. HP Pavilion dv2913cl RAM  Replacement: passo 2, imagem 1 %32 HP Pavilion dv2913cl RAM  Replacement: passo 2, imagem 2 %32 HP Pavilion dv2913cl RAM  Replacement: passo 2, imagem 3 %32
    • Gently push the silver clamps on both sides of the RAM stick on top.
    • Pushing the clamps back could damage the device. push far enough to remove the RAM card.
    • Now remove the RAM stick on top from the device.
  3. HP Pavilion dv2913cl RAM  Replacement: passo 3, imagem 1 %32 HP Pavilion dv2913cl RAM  Replacement: passo 3, imagem 2 %32 HP Pavilion dv2913cl RAM  Replacement: passo 3, imagem 3 %32
    • Gently push the silver clamps on both sides of the bottom RAM stick.
    • Pushing the clamps back could damage the device. Push gently just far enough to remove the RAM stick.
    • Now remove the bottom RAM stick from the device.
  4. HP Pavilion dv2913cl RAM  Replacement: passo 4, imagem 1 %32
    • this is the device with both RAM sticks removed.
Conclusão
Jeremy Jackson
Membro desde: 10/27/16
201 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 2-7, Isaacson Fall 2016 Membro de UMass Dartmouth, Team 2-7, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G7
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 104
