Ir para o conteúdo principal
HP Pavilion dv2913cl Keyboard Replacement
O que você precisa
  1. HP Pavilion dv2913cl Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Locate battery on the bottom of the laptop.
  2. HP Pavilion dv2913cl Keyboard Replacement: passo 2, imagem 1 %32
    • Slide the battery release bar to the left, this should release the battery so you can then remove it.
  3. HP Pavilion dv2913cl Keyboard Replacement: passo 3, imagem 1 %32 HP Pavilion dv2913cl Keyboard Replacement: passo 3, imagem 2 %32
    • Locate the three screws for the keyboard by finding the small keyboard picture, remove these screws and flip the laptop back over.
  4. HP Pavilion dv2913cl Keyboard Replacement: passo 4, imagem 1 %32
    • Open the laptop so the keyboard is facing upwards and towards you.
  5. HP Pavilion dv2913cl Keyboard Replacement: passo 5, imagem 1 %32 HP Pavilion dv2913cl Keyboard Replacement: passo 5, imagem 2 %32
    • Use the plastic opening tool to get underneath the plastic bar above the keyboard, pry upwards. Pry the keyboard upwards gently.
    • Be careful not to pull the keyboard too hard so you do not rip the silver ribbon cable attached to the laptop.
  6. HP Pavilion dv2913cl Keyboard Replacement: passo 6, imagem 1 %32 HP Pavilion dv2913cl Keyboard Replacement: passo 6, imagem 2 %32
    • Release the ribbon cable by using a flathead screw driver. Release the two tabs holding the cable and pull outwards.
    • Pull the keyboard up and out from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Adam Braga
Membro desde: 10/24/16
230 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 2-7, Isaacson Fall 2016 Membro de UMass Dartmouth, Team 2-7, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G7
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 161
